Pass :wink:
I'm with Lee on this one. Won't be easy to emulate.
This will 'sort-of' do what you want, but it's ugly...
(defun test (/ *error* check ent)
 (setq *error* (lambda (x)
                 (and check
                      (vla-put-mspace
                        (vla-get-activedocument (vlax-get-acad-object))
                        :vlax-false
                      ) ;_ vla-put-mspace
                 ) ;_ and
               ) ;_ lambda
 ) ;_ setq
 (and (setq check (zerop (getvar 'tilemode)))
      (vla-put-mspace (vla-get-activedocument (vlax-get-acad-object)) :vlax-true)
 ) ;_ and
 (while
     (setq ent (car (entsel "\nSelect Arc: ")))
     (cond ((eq 'ENAME (type ent))
            (if (not (and (eq "ARC" (cdr (assoc 0 (entget ent))))
                          (eq "0" (cdr (assoc 8 (entget ent))))
                     ) ;_ and
                ) ;_ not
              (princ "\n** Object is not an Arc on Layer \"0\" **")
            ) ;_ if
           ((princ "\n** Nothing Selected **"))
     ) ;_ cond
   ) ;_ progn
 ) ;_ while
 (*error* nil)
 ent
) ;_ defun
If I were to use this, I'd do a bit of cleaning up (serves it's purpose of demonstration). I'd also incorporate the check of (getvar 'errno) to enable the user to right-click out.
  • Replies 20
  • KRBeckman
    9
  • Lee Mac
    7
  • alanjt
    4
  • CALCAD
    1
Popular Days
