I have a dynamic block that was WBLOCKed to a file. If I insert the block through Design Center, all is well. However, if I browse for the same block (or insert it through .InsertBlock in VBA), the block loses all of it's dynamic properties AND attributes.
Has anyone else experienced this?
Probably it becomes a 'nested block'? Have you tried to explode it?
Out of curiosity, why would you need to use VBA to insert a block. There are a few ways that, to me at least, would be much easier to use rather than VBA to insert a block. You might want to explore the Tool Palette option. It looks like you're having the same issue I have on some of the dynamic blocks when I copy and paste them after they've been modified.
I have to add multiple blocks to 2200 drawings. With VBA I can put the right block in the right place automatically.
