ubh65 Posted March 3, 2010 Posted March 3, 2010 Hi, This is my first post. I am trying to find the font file and the text height used in a text to be picked by user. After finding that I want to produce a Text Style having the same properties but with a different name. Can any body help. Quote
Tiger Posted March 3, 2010 Posted March 3, 2010 Why don't you just find the text style in question (highlight the text, bring up Properties), go into Style Manager and make a copy of the style there? Quote
ubh65 Posted March 3, 2010 Author Posted March 3, 2010 Thanks. I just accomplished the goal. Below is the code: Public Sub setTextProp() Dim XdataSel As AcadSelectionSet Dim AcadEnt As AcadText Dim txtStyle1 As AcadTextStyle Dim TextStyleCollection As AcadTextStyles Dim txtFont1 As String On Error GoTo TrapErr Call AcClass.InitCADLoad AcadDoc.Utility.Prompt "Select The Text Object to Copy its Properties..." Set XdataSel = AcClass.SelObjects If XdataSel.Count = 0 Then MsgBox "No Entity Selected", vbInformation ErrFlag = True Exit Sub End If Set AcadEnt = XdataSel.Item(0) Set TextStyleCollection = AcadDoc.TextStyles For Each txtStyle1 In TextStyleCollection If txtStyle1.Name = AcadEnt.StyleName Then AcadDoc.ActiveTextStyle = txtStyle1 Exit For End If Next txtFont1 = txtStyle1.fontFile LoadtxtHt1 = txtStyle1.height If AcadEnt.height > LoadtxtHt1 Then LoadtxtHt1 = AcadEnt.height End If Call SetTextStyle(LoadtxtHt1, txtFont1) TrapErr: End Sub Private Sub SetTextStyle(txtHt As Double, txtFont1 As String) Dim TextColl As AcadTextStyles Dim txtStyle As AcadTextStyle Set TextColl = AcadDoc.TextStyles Set txtStyle = TextColl.Add("U2Q") txtStyle.height = txtHt txtStyle.fontFile = txtFont1 AcadDoc.ActiveTextStyle = txtStyle AcadDoc.SetVariable "USERR1", txtHt End Sub Quote
