hatch trim in 2d dwgs-AutoCAd-2004 - need lisp
hai
i need Hatch trim-lisp for AutoCAD-2004-if anybody have
please help me.
:geek:
hai
anybody have a lisp for Hatch Trim-For Autocad 2004
Can you explain a bit more what you are meaning by 'Hatch Trim'?
Are you trying to trim a set of hatch lines to a new boundry or is it something else?
Associative hatches will change as you change (eg. stretch) the end points.
I have not seen anything that will trim existing hatch to a new boundry without first exploding it which is a horrible idea.
It is usually easier to delete the old hatch and re-hatch the area you want.
Newer versions of Autocad allow you to trim hatches, so vanacharlasekhar must be looking for a custom routine that will do the same in older versions. I have never come across such a routine, but admittedly, I've never actually looked for one. :unsure:
I have moved this request to the lisp and customization section.
