Enhanced Attribute Block problem
Hi,
I am a bit out of my depth here!
I've received a plan with text dotted all over it, which doesn't seem to be 'normal text'. When I double click on it, it comes up with an enhanced attribute editor window.
All I need to do with it is to roughly double the size of this text universally on the plan, because it's too small for the scale I'm planning to use. If it were normal text, I'd select all of it, and modify the height in the properties window. I don't get the option with this text.
If I explode this text, the text changes, so I can't do this.
The only option I can see at the moment is to enlarge each one, one by one, which will take ages, as there's a lot of it!
Any help would be much appreciated.
Thanks,
Alex
if you have Express Tools, you can use command BURST, which explodes blocks, converting attribute values to text objects.
Great Geobuilder, that's very helpful. Thank you!
You could open the properties pallette, select all the blocks, look for the block scale factor and increase x2
Brilliant Pablo Ferral! Thank you.
