guitarguy1685 Posted March 5, 2010 Posted March 5, 2010 I have a few Lisps that insert blocks. The Lisp uses the full file path to locate the drawing and then insert. However if a block already exists in the drawing with the same name the Lisp will use the file in the drawing NOT the one defined by the path. If I use the standard insert dialog box and navigate the file and then try to insert I will be promted if I want to redifine it. How can I get this option to redfine in LISP? Quote
Lee Mac Posted March 5, 2010 Posted March 5, 2010 I sometimes use vla-insertblock to insert a block and this always redefines the existing block. PS> Redefine ~ sorry couldn't help it. Quote
The Buzzard Posted March 5, 2010 Posted March 5, 2010 PS> Redefine ~ sorry couldn't help it. You do not miss a trick. Quote
gilsoto13 Posted March 5, 2010 Posted March 5, 2010 I have a few Lisps that insert blocks. The Lisp uses the full file path to locate the drawing and then insert. However if a block already exists in the drawing with the same name the Lisp will use the file in the drawing NOT the one defined by the path. If I use the standard insert dialog box and navigate the file and then try to insert I will be promted if I want to redifine it. How can I get this option to redfine in LISP? What's exactly what you want? http://www.cadtutor.net/forum/showthread.php?t=40217 http://forums.augi.com/showthread.php?p=1035107 http://forums.augi.com/showthread.php?t=74579&highlight=blockredef http://paracadd.com/lisp/lisp_lst.htm ;;;Redefine a block and update its attributes ;;; ******************************************************************* ;;; ATTREDEF.LSP Quote
guitarguy1685 Posted March 5, 2010 Author Posted March 5, 2010 I sometimes use vla-insertblock to insert a block and this always redefines the existing block. PS> Redefine ~ sorry couldn't help it. "Redefine" is for rookies . seriously thought I don't mind being corrected. That wasn't a type I just spelled it wrong lol Quote
Lee Mac Posted March 5, 2010 Posted March 5, 2010 http://forums.augi.com/showthread.php?p=1035107 Wow, my code does get around... Quote
guitarguy1685 Posted March 5, 2010 Author Posted March 5, 2010 I tried this (defun C:test () (vl-load-com) (vla-insertblock (getpoint) "L:/DrawingUtilities/F-Part" 1 1 1 0) ) but I get this error error: bad argument type: VLA-OBJECT (-85.2136 19.2445 0.0) Quote
Lee Mac Posted March 5, 2010 Posted March 5, 2010 Have you looked at the reference in the Visual LISP Help file? InsertBlock method Arguments: Object: ModelSpace, PaperSpace, Block The objects this method applies to. InsertionPoint: Variant (three-element array of doubles); input-only The 3D WCS coordinates specifying the location in the drawing to insert the block. Name: String; input-only The name of the AutoCAD drawing file or the name of the block to insert. If it is a file name, include the .dwg extension and any path information necessary for AutoCAD to find the file. Xscale: Double; input-only; optional The default equals 1.0. Must be a positive number. Yscale: Double; input-only; optional The default equals 1.0. Must be a positive number. Zscale: Double; input-only; optional The default equals 1.0. Must be a positive number. Rotation: Double; input-only; optional The default equals 0.0 radians. Password: Variant; input-only; optional __________________________________________________ Return Value: BlockRef object The placed block as a Block Reference object. Quote
Lee Mac Posted March 5, 2010 Posted March 5, 2010 You will need to provide the Block VLA-Object into which you wish to insert the block (i.e. Model/Paper Space, Block definition). And the Point will need to be a Variant. As an example: (defun InsertBlock (bNme Pt) (vl-load-com) ;; Lee Mac ~ 05.03.10 (vla-InsertBlock (if (eq acPaperSpace (vla-get-ActiveSpace (setq doc (vla-get-ActiveDocument (vlax-get-acad-object))))) (if (eq :vlax-true (vla-get-MSpace doc)) (vla-get-ModelSpace doc) (vla-get-PaperSpace doc)) (vla-get-ModelSpace doc)) (vlax-3D-point Pt) bNme 1. 1. 1. 0.)) (defun c:test (/ iPt file) (if (and (setq iPt (getpoint "\nPick point for Block: ")) (setq file (findfile "L:\\DrawingUtilities\\F-Part.dwg"))) (InsertBlock file iPt)) (princ)) Quote
guitarguy1685 Posted March 10, 2010 Author Posted March 10, 2010 i did look at the help files and I thought I had done it right. i'm going to go through the afralisp VLisp tutorials. Seeing you guys use all the vl- stuff makes me jealous . Ijust did the "Beginning" tutorial and I think it just blew my mind. Quote
