the-trooper Posted March 10, 2010 Posted March 10, 2010 Hello everyone I have several dynamic blocks that ware created for the wrong scaling... Now i have to scale everything inside them by factor 10, but selection rectangles (for action selection set) don't scale. Is there some workaround for this, or will i have to manually adjust every one? I know the simplest way would be to simply scale the block itself, but than it would always have "Scale X: 10" and i just hate that! Thanks in advance! Quote
dbroada Posted March 11, 2010 Posted March 11, 2010 I would redefine each block definition at the correct scale with BEDIT. If you have a lot to do somebody may have a lisp you can use but for a few I'd settle for redefinition. Its quite easy. Quote
