Hi guys & Gals
We have a bit of a wierd situation we have 1 pc that when we go to run a VBA program it opens the VBA manager and jumps to a point in the code.
We have 8 pc's in total all others work fine.
Any ideas would be helpfull.
Not sure about your environment, but check the Local Settings in Control Panel on that particular station – you may learn that it use "," as decimal separator instead of "." and this will raise an error when a numerical string is passed to CDbl function.
Regards,
Thanks for your suggestion but where do you find this Local settings to change can not seem to find anything in control panel that changes the , to a .
Please use the route below to locate the symbol that is used as decimal separator on a workstation:
Control Panel --> Regional and Language Options --> Regional Options --> Customize... --> Numbers --> Decimal symbol
Regards,
