vjsasi Posted March 12, 2010 Share Posted March 12, 2010 Hi all.. When you use the pedit command and select a line to convert it into a pline, you are asked "the selected oblect is not a polyline, do you want to turn it into one?" There is a command by which you can stop this... anyone knows what that is? Thanx... Quote Link to comment Share on other sites More sharing options...
Fire_col Posted March 12, 2010 Share Posted March 12, 2010 Sorry you're not making much sense, if you want to select a line to make it a poly line then why would you want to disable the function that turns it into one? Quote Link to comment Share on other sites More sharing options...
vjsasi Posted March 12, 2010 Author Share Posted March 12, 2010 I intend to turn the line into a pline, thats the reason i went for the pedit command in the first place. I dont see any point in being asked again, IF i want to convert the line into a pline.. Thats what i meant.. Quote Link to comment Share on other sites More sharing options...
Fire_col Posted March 12, 2010 Share Posted March 12, 2010 Oh, well just select yes, because then that's it pedit does a lot more than just turn lines in to plines, once it's turned it into one it won't ask you again but will give you lots of other options for editing plines. Quote Link to comment Share on other sites More sharing options...
SEANT Posted March 12, 2010 Share Posted March 12, 2010 PEDITACCEPT system variable. Quote Link to comment Share on other sites More sharing options...
vjsasi Posted March 12, 2010 Author Share Posted March 12, 2010 Thanks mate.. Quote Link to comment Share on other sites More sharing options...
