SFG13 Posted March 14, 2010 Posted March 14, 2010 Hi, I have a drawing of a circle with the diameter of 1.631. The top middle of the circle has a diameter of .251. I want to dimensions the diameter of the entire circle with two lines that are horizontal with the distance of 1.631. I first drew a horizontal line, offset, etc. I tried to dimension the diameter of the lines but it wouldn't allow me to at all. Did I do something wrong? I don't know why? Quote
SFG13 Posted March 14, 2010 Author Posted March 14, 2010 Actually I found out by dimension and linear so I'm okay now! Quote
JD Mather Posted March 14, 2010 Posted March 14, 2010 Actually I found out by dimension and linear so I'm okay now! I'm curious to see this circle with different diameters. Can you attach the file here? Quote
SFG13 Posted March 14, 2010 Author Posted March 14, 2010 Hi JD, I would like to show you but how do I attach it? I'm working on it right now. I'm trying to trim the bottom line of the 1.63 dmension but it would trim too much off compared to my professor's demo. Is there a way I can make it similar in length? Quote
