How to extrude 3dface object
Hi All,
i am working on vba as backend, the frontend is autocad i dont know how to extrude 3DFace object programatically can any one help how to extrude a 3DFace object
Thanks in Advance,
Srikanth
Can you post it and I'll have a look at it for you?
Sub Example_Add3DFace()
' This example creates a 3D face in model space.
Dim faceObj As Acad3DFace
Dim point1(0 To 2) As Double
Dim point2(0 To 2) As Double
Dim point3(0 To 2) As Double
Dim point4(0 To 2) As Double
' Define the four coordinates of the face
point1(0) = 0#: point1(1) = 0#: point1(2) = 0#
point2(0) = 5#: point2(1) = 0#: point2(2) = 1#
point3(0) = 1#: point3(1) = 10#: point3(2) = 0#
point4(0) = 5#: point4(1) = 5#: point4(2) = 1#
' Create the 3DFace object in model space
Set faceObj = ThisDrawing.ModelSpace.Add3DFace(point1, point2, point3, point4)
ZoomAll
End Sub
i want to extrude this faceObj is it possible
Thanks in advance
No, sorry, I meant can you post the drawing file?
actually it is extruding in front end
i want it programatically
Right, Sorry I'm afraid that's a bit beyond my talents.
I would reccommend moving this thread to the 3d forum or the autolisp/VBA forum, you'll get the help you require from there.
