kyosmith Posted March 15, 2010 Posted March 15, 2010 Hello all! Please help with this: I need to define an attribute that automatically gets another attribute value then uses a formula to calculate it self atributte. If you dont understand what im asking: Example: atributte A = 5 atributte B = (atributte A value) +10 then atributte B final value = 15 Thanks all! Quote
Tommy78 Posted March 15, 2010 Posted March 15, 2010 That is unfortunately not possible, as far as i know you can't put formulas in attributes. Maybe it's possible to make a script to obtain the desired result, let's see if any of the local lisp wizards find a solution... Quote
lpseifert Posted March 15, 2010 Posted March 15, 2010 Not easily without using lisp or similar. You could create attributes with formula fields that reference cells in a table. But it's probably more trouble than it's worth, and I don't know if LT would support that method Quote
