michaeloureiro Posted March 16, 2010 Posted March 16, 2010 Hey everybody, I´ve been trying to get a way to rotate the text in a section callout but i can´t seem to configure the rotation point centered with the text. I´m using cad09 LT Can anybody help? section.dwg Quote
AJSmith Posted March 16, 2010 Posted March 16, 2010 sorry i dont follow do you want to rotate the text separate to the lines?? i have this section line with a rotation grip if thats what you looking for Sections Line Block.dwg Quote
Tommy78 Posted March 16, 2010 Posted March 16, 2010 It's best to put your rotation point in the center (insert point) of your text. You will also have to include the rotations in the flip action and create a stretch action instead of just distance which includes the rotations. Hope that helps. Quote
michaeloureiro Posted March 16, 2010 Author Posted March 16, 2010 I´ll have to try the insert point tommy 78. I was looking only to rotate the text AJ Smith Quote
michaeloureiro Posted March 16, 2010 Author Posted March 16, 2010 Tommy 78, did you mean base point, cause it still isn´t working.... Quote
Tommy78 Posted March 16, 2010 Posted March 16, 2010 I was a bit bored, so i made it for you (see attach) The trick is to put the rotation center at the insert point of the text (align=middle center!) and then you have to include your rotation actions and grips in the flip and stretch selection sets, if you don't do this the rotation doesn't work correct. Check it in the block editor to see how it was made. section_NEW.dwg Quote
