Hi,
I have a question. I used the "insert block" option to put parts together to assmble. I found that I can't subtract, it seems that the parts are no longer 3D .. :x ... is there any other way ? or do I just have to copy and past all the basic parts in ?
thanks in advance.
hi, you'll need to post in the 3D modeling and rendering section of the forum for this question.
I suspect your trying to subract solids, if you use insert then it means your solid is a block. you'll need to explode it first and then subtract. you cant subract solids if it is a block. just like basic lines, you cant trim them if it is a block unless you edit the block itself with BEDIT.
I'll give it a try.
sry big newb here so I thought the beginner's section is the way. I'll post in the 3D modelling section next time. :shock:
Thanks
