h0wi3 Posted August 21, 2008 Share Posted August 21, 2008 Hi, I have a question. I used the "insert block" option to put parts together to assmble. I found that I can't subtract, it seems that the parts are no longer 3D .. ... is there any other way ? or do I just have to copy and past all the basic parts in ? thanks in advance. Quote Link to comment Share on other sites More sharing options...
nocturne00 Posted August 21, 2008 Share Posted August 21, 2008 hi, you'll need to post in the 3D modeling and rendering section of the forum for this question. I suspect your trying to subract solids, if you use insert then it means your solid is a block. you'll need to explode it first and then subtract. you cant subract solids if it is a block. just like basic lines, you cant trim them if it is a block unless you edit the block itself with BEDIT. Quote Link to comment Share on other sites More sharing options...
Strix Posted August 21, 2008 Share Posted August 21, 2008 I'll move it to the right section Quote Link to comment Share on other sites More sharing options...
h0wi3 Posted August 21, 2008 Author Share Posted August 21, 2008 I'll give it a try. sry big newb here so I thought the beginner's section is the way. I'll post in the 3D modelling section next time. Thanks Quote Link to comment Share on other sites More sharing options...
