A few basic questions when I work on the assessment test
Which of the following CANNOT be performed using the Quick View Drawings shortcut menu?
Save all drawings (It can save, but not save all)
Arrange the open drawings (It display the object, but cannot arrange)
Which of the following is not an Effect option that can be set in a text
style
Backwards
Mirror
Vertical
Oblique Angle
(I think backwards cannot be set, but really not sure. Even if Mirror can be set, but Mirror command should be an object style. The other two are just like Mirror)
Which of the following is a valid method for adding a command or block to a tool palette
Right-click on the tool palette and select New Block
Use the Tools text menu> New Block
Drag a command from a toolbar
Right-click and drag a single piece of geometry from the drawing area to a palette
(I am not sure how to use the tool palette, I thought I can use the existing block only)
Link to post
Which of the following is not an Effect option that can be set in a text...
All you need to is run the Style command to answer this question. I suggest that you rethink your answer.
Link to post
Could you please give me some suggestion on the other two?? :lol:
Link to post
Which of the following is a valid method for adding a command or block to a tool palette...
AutoCAD Help files. See Tool Palettes > Adding tools > Concept tab.
How's that?
Link to post
