I’m trying to locate the closest point to selection point on a line contained in a block (the only one item in that block); that it, I’m looking for a point that lays on that entity. By using code below seems that the line is recognized as misplaced?!?
(setq UserSelection (nentsel "\nSelect line (in block): ")
     LineFromBlock  (car  UserSelection)
     SelectionPoint (cadr UserSelection))
(setq ClosestPoint (vlax-curve-getClosestPointTo (vlax-ename->vla-object LineFromBlock)
                                                SelectionPoint
                                                T))
(command "CIRCLE" ClosestPoint 1.0)   ;DEBUG ONLY
Can someone help solve my issue? Thank you!
Regards,
Try this
     SelectionPoint (OSNAP(cadr UserSelection) "NEA"))
(command "CIRCLE" SelectionPoint 1.0)   ;DEBUG ONLY
Yes, the point lays on line now. Thank you very much!
Have done a lot of tests with my code trying to understand the result and its strange how the debug points tend to align to a fictive line.
Can't answer for sure but it may have something to do with the difference with the UCS and ECS (Entity Coordinate System, which blocks use for definition of the entities within)
But I could be wrong...
Already tried to convert the point to/from Entity Coordinates System (used entity name as argument for TRANS function) but no luck…
I don't think TRANS will work directly for the conversion; a transformation matrix is needed. I'm sure someone else on this forum could explain/demonstrate the method better than I, I've just read about it.
Msasu,
For a nested object, you will need to use the transformation matrix returned by nentsel to get the correct points.
Will post an example in a bit. :)
I figured post #6 would get you involved...
Hehe
Something like this Msasu:
(defun GetClosestNested (/ ent cPt Matr pt)
 (vl-load-com)
 (if (and (setq ent (nentselp "\nSelect Line in Block: "))
          (setq cPt (getpoint "\nSelect Point to Test: ")))
     (setq Matr (caddr ent)
           ent  (entmakex (append (entget (car ent)) '((60 . 1)))))
     (if Matr (vla-transformby
                (vlax-ename->vla-object ent) (vlax-tmatrix Matr)))
     (setq pt (vlax-curve-getClosestPointto ent cPt))
     (entdel ent)))
 pt)
(defun c:test (/ p)
 (if (setq p (GetClosestNested))
   (entmakex (list (cons 0 "POINT") (cons 10 p))))
 (princ))
@lpseifert, @Lee Mac and @alanjt - Thank you very much for your solutions and examples!
Hope it helped. :)
You're welcome Msasu, happy to help. Its a shame a copy must be created, as this can be a problem if used within a loop but, if made invisible (as in my example), you needn't delete it til after the loop, meaning the routine is less CPU intensive.
I went the long way, works with non-uniformly scaled blocks, rotated blocks, non-world ucs:
;;  SAMPLE ROUTINE TO TRANSFORM POINT FROM/TO BLOCK COORDINATE/UCS
     blockinspoint  (cdr (assoc 10 (entget (car (last UserSelection)))))
     blockscale_x   (cdr (assoc 41 (entget (car (last UserSelection)))))
     blockscale_y   (cdr (assoc 42 (entget (car (last UserSelection)))))
     blockscale_z   (cdr (assoc 43 (entget (car (last UserSelection)))))
     blockrotation  (cdr (assoc 50 (entget (car (last UserSelection)))))
(setq ClosestPoint
            LineFromBlock
            ;;  TRANSFORM SELECTIONPOINT COORDINATE FROM
            ;;  USER COORDINATE SYSTEM TO
            ;;  BLOCK COORDINATE SYSTEM
            ;;  UCS->WORLD => MOVE => ROTATE => SCALE
            (mapcar '/
                    (polar '(0 0 0)
                           (- (angle '(0 0 0)
                                     (mapcar '-
                                             (trans SelectionPoint 1 0)
                                             (polar '(0 0 0)
                                                    (angle '(0 0 0) blockinspoint)
                                                    (distance '(0 0 0) blockinspoint)
                              blockrotation
                           (distance '(0 0 0)
                                     (mapcar '-
                                             (polar '(0 0 0)
                    (list blockscale_x blockscale_y blockscale_z)
(setq ClosestPoint
        ;;  TRANSFORM CLOSESTPOINT FROM
        ;;  TO USER COORDINATE SYTEM
        ;;  SCALE => ROTATE => MOVE => WORLD->UCS
        (trans
            (mapcar '+
                    (polar '(0 0 0)
                           (+ (angle '(0 0 0)
                                     (mapcar '*
                                             ClosestPoint
                              blockrotation
                           (distance '(0 0 0)
                                     (mapcar '*
                                             ClosestPoint
                    (polar '(0 0 0)
            0
            1
;;WIZ_20MAR10--------------------------------------------------------------------------------
