Benoldays Posted March 19, 2010 Share Posted March 19, 2010 Hi everyone. Ive just started using 2010 after spending the last few years on 2007 and 08. I completely skiped 9 so this change may have happened then. The problem im having is when I select a line im unable to edit the length of that line by changeing the "length" value in the properties palette. the little box is greyed out and i can only access the calculator when i click on the number box. Im so used to changing values of objects on the fly this way its kinda annoying. Thanks for your help. Quote Link to comment Share on other sites More sharing options...
Pablo Ferral Posted March 19, 2010 Share Posted March 19, 2010 I can confirm that this doesn't work in 2009...No idea why it's changed though. Quote Link to comment Share on other sites More sharing options...
lpseifert Posted March 19, 2010 Share Posted March 19, 2010 Using 2008... the Length property is greyed out for lines, plines, arcs... I don't think you could ever edit length via Properties. Quote Link to comment Share on other sites More sharing options...
BWells Posted March 19, 2010 Share Posted March 19, 2010 Instead of the properties palette you could jjust use the lengthen command. (quick key: Len) I realize this may not be the answer your looking for but in long run it can be much faster. Quote Link to comment Share on other sites More sharing options...
DVDM Posted March 22, 2010 Share Posted March 22, 2010 Alternatively, if you turn on Dynamic Input, and then hover over one of the endpoint handles of an object, it will show you the length/angle of that object. If you then left-click on that handle you can then use the Tab key to cycle through the different values (length, angle, radius), and key-in the value you want to give it. At least this way, when changing the length of a line, you can choose from what base you want to lengthen/shorten. Quote Link to comment Share on other sites More sharing options...
