som Posted March 19, 2010 Posted March 19, 2010 Hello, i'm here because I have a problem with autocad lt 2010 on windows 7 32 bit. The properties window (right click on an object like a MEASUREGEOM -> Properties) has blank areas. It has render problems and when I use the scroll to go up and down with properties list it is very slow. I have done: - Updated graphic card driver ( nvidia quadro fx 770m) - Reinstalled autocad lt 2010 The problem is still here. Some tips? thank you Quote
ReMark Posted March 19, 2010 Posted March 19, 2010 I probably would have suggested a REPAIR as opposed to a reinstall but too late I see. When did the problem first occur? Have you downloaded and installed Update 1 for AutoCAD LT 2010? Quote
som Posted March 22, 2010 Author Posted March 22, 2010 Thank you ReMark, can I repair now the last reinstallation? Update 1 installed, the problem isn't fixed. The pc is a new one, I think that this autocad doesn't work fine from the beginning. Quote
ReMark Posted March 22, 2010 Posted March 22, 2010 I don't know if using the REPAIR option will work considering a reinstall didn't. What are the specs on your computer? Quote
som Posted March 22, 2010 Author Posted March 22, 2010 Specs: - CPU Intel T9600 - Windows 7 Prof. 32 bit - ram 4 GB - hd: 320GB Serial ATA - graphics card: NVIDIA fx 770M Quote
ReMark Posted March 22, 2010 Posted March 22, 2010 Judging by your specs there shouldn't be a problem running AutoCAD LT. I'm finding it difficult to believe you could have two bad installs. When you did the first removal of AutoCAD did you follow the recommended procedure set out by AutoDesk? Quote
som Posted March 22, 2010 Author Posted March 22, 2010 I used the complete uninstall from Control Panel -> Programs and Features -> Remove/Change and then I selected "Remove" on Autodesk's interface. Is it the recommended procedure? Quote
ReMark Posted March 22, 2010 Posted March 22, 2010 AutoDesk says there are a couple of folders that require manual removal. Maybe the uninstall process doesn't quite get everything. Instructions can be found at the AutoDesk website. Do a search on the words "clean installation". Quote
som Posted March 22, 2010 Author Posted March 22, 2010 Thank you ReMark, I finded that at the autodesk website. I will try to remove Autocad using that instructions. You're very kind. Quote
ReMark Posted March 22, 2010 Posted March 22, 2010 You might consider loading AutoCAD "flat" from your hard drive instead of the DVD. This would require creating a temp file to copy of the contents of the disk too and then loading AutoCAD right from your hard drive. If AutoCAD prompts you for the location of files point it to this temp folder. Quote
som Posted March 22, 2010 Author Posted March 22, 2010 Ok. I will do it soon. I'm keeping my fingers crossed. Quote
som Posted March 22, 2010 Author Posted March 22, 2010 Nothing Autocad reinstalled after a clean uninstallation. --> The problem is not fixed. I tried a REPAIR but did not work. May I reinstall the operative system? May I try other ways before? Quote
ReMark Posted March 22, 2010 Posted March 22, 2010 Reinstalling the OS is always an option. Seems a pity you would have to resort to such drastic measures though. Quote
ReMark Posted March 22, 2010 Posted March 22, 2010 Want to update us som? Did you wipe the HD and start from scratch? Quote
Car5858 Posted March 22, 2010 Posted March 22, 2010 I would suggest that you turn off the anti-viris program before doing a repair / reinstallation. You may also want to turn of the registry cleaners also. Quote
som Posted March 23, 2010 Author Posted March 23, 2010 @ReMark No. I can't reinstall all s.o. until week-end. @Car5858 Yes. Antivirus was turned off Many thanks! Quote
som Posted March 23, 2010 Author Posted March 23, 2010 I did this test: Uninstalled the graphic card 's driver and without a driver (at low screen resolution) the problem is fixed. Reinstalled the driver, at the same screen resolution, the problem comes back. Now I must find a good driver that works fine... Quote
ReMark Posted March 23, 2010 Posted March 23, 2010 That's interesting. What keyed you to the driver? Quote
som Posted March 23, 2010 Author Posted March 23, 2010 The first is supplied from Dell ( nVidia 188.40 WHQL driver (Win7/Vista 32bit) ) then I have installed the last driver 197.03 realesed on March 19, 2010 from nVidia website from quadro fx 770m. Quote
