Cad64 Posted March 30, 2010 Posted March 30, 2010 Update: I've opened and closed many drawings over the last 4.5 hours, currently I have 3 drawings open and my memory usage is up to 930mb. Quote
engosara Posted September 14, 2011 Posted September 14, 2011 i have got aproblem in cad 2010 it damged that happend when i creat anew user and delet the old one and when i got started the cad 2010 this massge is apeared ((customization file load failed .file not found :acad )) and when i tried to remove cad2010 also it is not working even i uesd your unistaller program >>about my computer is asus .system windows7 64 bit cpu p8700 2cord--2.53GHz-Ram 4 G plz plz help me soon i have an er thaaaanks Quote
engosara Posted September 14, 2011 Posted September 14, 2011 any body here pllllllllllllllllllllllllz help me :( Quote
ReMark Posted September 14, 2011 Posted September 14, 2011 Try to control yourself please. While it may seem like the end of the world it really isn't. You created a new user and deleted the old user. I won't even ask why. Then you could not load the CUI. To fix the problem you tried to uninstall AutoCAD the "uninstall program" did not work. Are these statements correct? Since you were unable to uninstall AutoCAD what happens now if you try to load it? Quote
engosara Posted September 14, 2011 Posted September 14, 2011 first thanks for help and hear my voice next when the cad is not worked with me i tried to remove it from the control panal but it doesnt work so i down load aremover program named your unistaller to remove the cad but also did remove >>>>> Quote
engosara Posted September 14, 2011 Posted September 14, 2011 about what u said is correct statement >>>> and about the load when i tried to do it it doesnt work coz it said the program is all ready installed Quote
engosara Posted September 14, 2011 Posted September 14, 2011 plz can u find asolution for me coz i have to work and there is no time with me Quote
Cad64 Posted September 15, 2011 Posted September 15, 2011 You really need to learn some patience. Is this a legal copy of Autocad? If so, insert the installation disk and run a Repair. If that doesn't work you should probably contact Autodesk and explain your situation to them. Quote
engosara Posted September 15, 2011 Posted September 15, 2011 in the disk there is no repair choice and still say the program is all ready installed about what u say how can i contact with autodesk Quote
engosara Posted September 15, 2011 Posted September 15, 2011 in the disk there is no repair choice and still say the program is all ready installed about what u say how can i contact with autodesk thanks for help cad64 but still i have the problem:oops: Quote
Cad64 Posted September 15, 2011 Posted September 15, 2011 Yes, there is a Repair option. Insert the disk and choose to Repair or Reinstall. And please stop bumping this thread every 20 minutes. It's not going to help you get your problem solved any faster. Quote
Cad64 Posted September 15, 2011 Posted September 15, 2011 about what u say how can i contact with autodesk http://usa.autodesk.com/adsk/servlet/index?id=1073074&siteID=123112 Quote
engosara Posted September 15, 2011 Posted September 15, 2011 (edited) that what apear when I open the disk of cad2010 Edited September 15, 2011 by engosara Quote
ReMark Posted September 15, 2011 Posted September 15, 2011 To properly remove a program you need to do two things. First. Under Windows 7 you need to follow the instructions outlined here...http://windows.microsoft.com/en-US/windows-vista/Uninstall-or-change-a-program. Second. You also need to follow the recommended procedure for uninstalling AutoCAD as put forth by AutoDesk itself. For those instructions you need to go here...http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=2887771&linkID=9240617. Quote
engosara Posted September 15, 2011 Posted September 15, 2011 I fallow the first step and when i try to unistall the cad 2010 this apear Quote
ReMark Posted September 15, 2011 Posted September 15, 2011 You may have messed things up with your first attempt to uninstall. Did you create a Restore point when you first loaded AutoCAD? Quote
