I have a lisp routine here and it is works great for searching for a specific value of an attribute if that attribute is in the drawing. Is there a way to make this search the xrefs that are overlayed in the main drawing file as well as the main drawing?
(defun c:fatt (/ ov ss i en ed an ad ah)
 (while (not ov)
        (setq ov (getstring t "\nATTRIB Value To Search For:   ")))
 (and (setq ss (ssget "X" (list (cons 0 "INSERT")
                                (cons 66 1)
                                (if (getvar "CTAB")
                                    (cons 410 (getvar "CTAB"))
                                    (cons 67 (- 1 (getvar "TILEMODE")))))))
      (setq i (sslength ss))
      (while (not (minusp (setq i (1- i))))
             (setq en (ssname ss i)
                   ed (entget en)
                   an (entnext en))
             (while (/= "SEQEND" (cdr (assoc 0 (entget an))))
                    (setq ad (entget an)
                          ah (cdr (assoc 40 ad))
                          an (entnext an))
                    (if (= (strcase ov)
                           (strcase (cdr (assoc 1 ad))))
                           (command "_.ZOOM" "_C" (cdr (assoc 10 ed)) (* ah 66))
                           ;(redraw en 3)
                           (getstring "\nPress Enter To Continue Searching..."))))))
 ;(redraw)
 (prin1))
Nobody wants to take a stab at this? Does anyone know if it is even possible?
Hi,
(ssget "X" (list (cons 0 "INSERT")...
Is piece of the code that searches the current drawing for all blocks.
If a block is in an Xref, the "ssget" function does not work. The blocks with its attributes are nested therefore you must use the "nentsel" function. And that works only on a selection of 1 entity.
How to solve this is a riddle to me for I have tried to find a solution myself often.
If others out there have a solution or if I am totally mistaken here, please comment.
I made a start, just searching the block definition, not sure if it helps at all.
(defun c:Find_Att (/ itemp getname getnestattribblocks BLKS BLOCK ENT I LST NLST SS TMP)
 ;; Lee Mac  ~  23.03.10
 (setq *str (strcase
              (cond ((/= "" (setq tmp (getstring t "\nATTRIB Value to Search For: "))) tmp)
                    (*str))))
 (defun itemp (collection item / result)
   (if (not (vl-catch-all-error-p
              (setq result
                     (vl-catch-all-apply (function vla-item)
                       (list collection item)))))
     result))
 (defun GetName (object)
   (if (vlax-property-available-p object 'EffectiveName)
     (vla-get-EffectiveName object)
     (vla-get-name Object)))
 (defun GetNestAttribBlocks (object / result sub)
   (setq blks (cond (blks) ((vla-get-Blocks
                              (vla-get-ActiveDocument
                                (vlax-get-acad-object))))))
   (vlax-for sub object
     (if (and (eq "AcDbBlockReference" (vla-get-ObjectName sub))
              (eq :vlax-true (vla-get-hasAttributes sub)))
       (setq result (cons sub (GetNestAttribBlocks (itemp blks (GetName sub)))))))
   result)
 (if (setq i -1 ss (ssget "_X" (list (cons 0 "INSERT")
                                     (cons 66 1)
                                     (cons 410 (getvar 'CTAB)))))
   (while (setq ent (ssname ss (setq i (1+ i))))
     (setq bName (cdr (assoc 2 (entget ent))))
     (while (/= "SEQEND" (cdr (assoc 0 (entget (setq ent (entnext ent))))))
       (if (eq *str (strcase (cdr (assoc 1 (entget ent)))))
         (setq Lst (cons (cons bName ent) Lst))))))
 (vlax-for block (vla-get-Blocks
                   (vla-get-ActiveDocument (vlax-get-acad-object)))
   (setq nLst
     (cons
       (apply (function append)
              (mapcar
                (function
                  (lambda (block)
                    (vl-remove 'nil
                      (mapcar
                        (function
                          (lambda (attrib)
                            (if (eq (strcase (vla-get-TextString attrib)) *str)
                              (cons (GetName block) (vlax-vla-object->ename attrib)))))
                        (vlax-invoke block 'GetAttributes)))))
                (GetNestAttribBlocks block)))
     nLst)))
 (print (vl-remove 'nil (apply (function append) nLst)))
 (princ))
Thanks guys for replying. Lee Mac, I can't get this to work with a block that is in the drawing or in an xref. I am thinking along the lines of AutoCad's "Find" command. It has the capabilities to do what I want, but the regeneration process takes way too long on the size files I deal with. The lisp I posted regenerates a lot faster, it just isn't searching in the xref for the attribute.
ksperopoulos,
The posted code will only print a list of Block Names and the entity name of the attribute in which it appears - it is only a start, and would need much refinement.
Sorry, I must have misunderstood before. I do not know how to write lisp routines and know very little how to manipulate them. I thought maybe someone already may have encountered this before and had something they would be willing to share.
