When I print an A size drawing in paper space, I lose the dashed box (White) and my layout frame (Green) offsets to the left in the black area. I did my page setup fine and the print comes out OK, but now I cannot get the viewport back to the original state. The dashed box isn't even there anymore. I had to delete that tab and copy the second tab and rename it and put the area of that first tab back in it. I'm not an expert with paper space. Using 29009LT. I can't attach the file as it's 1.20 MB.
Glenn
USA
If you are referring to the dashed lines that define the printable area then you need to go to...
Tools > Options > Display tab.
Look in the lower left hand corner for Layout Elements and make sure there is a checkmark in the box for Display Printable Area.
ReMark, yes, that was on. I just checked. I also just ran another print and it happened again. I have to do an "UNDO" to get the page setup screen back to normal.
