I want to find perticular text in autocad drawing(master plan) showing with leader line because some other persons also want to see this, if you have any lisp for this please suggest and help me,
Thanks
If I understand correctly, you need to find a text that is associated with leader
Type in command line
(sssetfirst nil  (ssget "_X" '((0 . "MTEXT") (102 . "{ACAD_REACTORS"))))
LoL
Not at all how I read it.:wacko:
Thanks
Just a hint
(vl-load-com)
(defun C:demo(/)
(setq oldString "Yes" newString "No");<-- change the desired values here
(setq ss (ssget "X" '((0 . "LEADER"))))
(setq obj_list (mapcar 'vlax-ename->vla-object
        (vl-remove-if 'listp
   (mapcar 'cadr (ssnamex ss)))))
(foreach leader_obj obj_list
 (if (vlax-property-available-p leader_obj 'Annotation)
   (setq anno_text (vla-get-annotation leader_obj))
   (if (eq oldString (vla-get-textstring anno_text))
     (vla-put-textstring anno_text newString)
     (vla-update leader_obj)))))
~'J'~
I really have a problem with English.
Accordingly, I did not understand that alanjt meant
Not at all how I read it. :wacko:
I think something offensive.
Of course, there are many programs that are attached to the text of the reactor, but in the pure AutoCAD it doing only Leader
I just meant that I completely misread what he was asking.
