BSC_Intern Posted March 24, 2010 Posted March 24, 2010 Hey everyone, I am new here to the forums, I have a question, which I am not sure if is even possible, so I figured you guys would know. I am currently running a trial version of the 2010 inventor, and I wanted to use them on my 2008 inventor, but it is impossible to open them. Is there anyway to 'convert' the files from a 2010 format, to a 2008 format? Thank you. Tyler Quote
shift1313 Posted March 24, 2010 Posted March 24, 2010 Not as far as i know. You can ofcourse change the file type to iges or step but you will loose your history/model tree info. Why is it like that? not really sure but other parametric modeling software packages are the same way. Quote
JD Mather Posted March 24, 2010 Posted March 24, 2010 File>Save Copy As Type STEP (*.stp) If you need feature tree and sketches there is a Feature Recognition add-in here http://labs.autodesk.com Quote
shift1313 Posted March 24, 2010 Posted March 24, 2010 File>Save Copy As Type STEP (*.stp) If you need feature tree and sketches there is a Feature Recognition add-in here http://labs.autodesk.com That looks a lot better than Solidworks feature recognition but i wonder how well it works for models that are a bit more complex. Do you have experience with it JD? Quote
BSC_Intern Posted March 24, 2010 Author Posted March 24, 2010 Disregard my previous post. This is kind of a pain to do it this way, sometimes it does not recognize all the features and stuff, is there anything I can do about that? Thanks. Quote
JD Mather Posted March 24, 2010 Posted March 24, 2010 That looks a lot better than Solidworks feature recognition but i wonder how well it works for models that are a bit more complex. Do you have experience with it JD? As far as I know it works about the same as the SWx feature recognition. Out of luck for Sweeps and Lofts. Holes can be combined into patterns via RMB. I really haven't palyed with FR much, but these are my observations - most users try to automatically recognize every feature, what is the point. Is the entire part incorrect? I tend to prefer to use the manual recognition (in Inventor or SWx), recognizing only those features that actually need to be edited. Also I recognize them in the reverse order the part would be created - recognize fillets, holes, extrude-cuts, revolves, extrudes in that order. There is some interesting feature recognition in Inventor Fusion. Interesting because it isn't history based. If you get a chance watch this video. http://au.autodesk.com/?nd=class&session_id=5457 Oh, one more note - in Inventor 2010 Ribbon Interface the Return button to get out of FR environment is a bit tiny and hard to find. Quote
JD Mather Posted March 24, 2010 Posted March 24, 2010 Disregard my previous post. This is kind of a pain to do it this way, sometimes it does not recognize all the features and stuff, is there anything I can do about that? Thanks. That's the way it is with all history based parametric modelers. (actually I think the latest Pro/E does have some backward compatibility) But the question arises - is your entire part wrong such that you need to edit all features? If so you might look into free Inventor Fusion. http://au.autodesk.com/?nd=class&session_id=5457 Quote
BSC_Intern Posted March 25, 2010 Author Posted March 25, 2010 The reason that I want all the features on the 2008 file is in case some day down the road, the part needs to be edited for some odd reason; all the features need to be shown on the part. Thanks for your help though man. Quote
