retaining the color xref
Hi , Acad 2005,if you have an xref into host dwg and change color by layer manager.(first I did the visretain to 1) then I want to convert all the color layers to its original color what commands or procedure should I do? The xref have a lots of layers maybe 20 or more layers I want to convert rt away as fast as suppose to be not one by one.Any idea, thanks in advance.
If I follow you correctly- you can set VISRETAIN back to 0 and reload the xrefs. That will return all the layers to the original states.
Big Thanks for quick replied ,got your adviced.
