Hello everyone. I have a data extraction question. When you are using the data extraction tool in AutoCAD is there a way to extract the data in the order it was chosen? I have a ton of pieces scattered about a layout and I am trying to extract their lengths, but in the order that I pick them. It seem s as though the data extraction sorts them either in ascending or descending order. Am I missing a setting or something, does anybody know how to sort the extraction by order chosen?
There is not really an instant solution for this.
What you could do is add an invisible attribute (name: ORDER for example)to your blocks and put a number there in the order you want your blocks; 01,02,03.
Then sort descending by that attribute.
