Hey look at that, now I found it...:oops:
  • Replies 25
  • KRBeckman
    13
  • Lee Mac
    9
  • alanjt
    3
  • MSasu
    1
How about this part :)
For example:
 (initget 0 "Fart tOot")
 (getpoint "\nSpecify point or [Fart/tOot]: "))
The letter that is capitalized is the trigger, but it will accept the entire word (This is just useful when you have two keywords that begin with the same letter).
yeah, I've used the 2nd or 3rd letter keyword trigger a bunch, just didn't know you could use it with a getpoint or getreal....
I'm running into another problem... I'm trying to limit the input for a prompt so that on the first run it requires an input, but once the vairable has a value, you can press enter and it will use the previous value. The I've tried a few different approaches, but can't get it to work. Here's my latest attempt:
(initget (if (not tpm) 1 nil) "Face Array oScill layeR hidE")
   (setq tpm (cond
 ( (getpoint
     (strcat "\nPick First Point or choose setting to cycle [Face type/Array "
   "type/oScillation/layeR/hide Edges/<select point>]: ")))
 (tpm)))))
Any ideas?
 (or *Value* (setq *Value* "Chicken"))
 (initget "Beef Chicken")
 (setq *Value* (cond ((getkword (strcat "\nChoice meat? [beef/Chicken] <" *Value* ">: ")))
                     (*Value*)
               ) ;_ cond
 ) ;_ setq
) ;_ progn
Perhaps look at this thread:
http://www.cadtutor.net/forum/showpost.php?p=273108&postcount=12
It will demonstrate how to 'remember' an option :)
Or, in the way you were phrasing it,
(initget (if *def* 0 1) "Eggs Bacon")
(setq *def* (cond ((getkword (strcat "\nEggs or Bacon? "
                                    (if *def* (strcat "<" *def* ">") "") " : "))) (*def*)))
But that's a bit messy imo
