ninh Posted April 1, 2010 Posted April 1, 2010 When I copy an object from a drawing and paste to another drawing, it take a while. I did not have this issue before Please advise Thanks Quote
ReMark Posted April 5, 2010 Posted April 5, 2010 Is your version of AutoCAD current with all updates? Quote
ninh Posted April 6, 2010 Author Posted April 6, 2010 Hi Remark, How can I know my version is update ? I have 2008 Auto CAD Thanks Quote
ReMark Posted April 6, 2010 Posted April 6, 2010 Type the word About at the command line or select it from the pull-down menu under Help at the top of your screen. If the info is not immediately available on the window that pops up then click on the Product Information button on the right hand side. Another window should appear with further information. Quote
ninh Posted April 6, 2010 Author Posted April 6, 2010 Remark, Everything up to date. But it is still take a while for copy and paste Quote
ninh Posted April 6, 2010 Author Posted April 6, 2010 for example I left click on any object like a note and there are some dots on the object then I right click/copy or copy with base point then go to another drawing and right click/ pate It take a while to paste ( about 15 seconds ) I did not have this before in the command like it said '' _pasteclip dulicate definition block a15 ignored Quote
ReMark Posted April 6, 2010 Posted April 6, 2010 As posted by lyubomir at the AutoDesk Discussion Group re: slow copy / paste problem. Command: -scalelistedit Don't forget the dash in front of the word scalelistedit Enter option [?/Add/Delete/Reset/Exit] : R Reset scale list to defaults? [Yes/No] : Y Scale list reset to default entries. Enter option [?/Add/Delete/Reset/Exit] : E Try this and see what happens. Quote
ReMark Posted April 6, 2010 Posted April 6, 2010 Were the drawings you're having a problem with originally created with AutoCAD 2007? Quote
ReMark Posted April 6, 2010 Posted April 6, 2010 Yes, I know that. Did you create all the drawings yourself using AutoCAD 2008? Quote
ReMark Posted April 6, 2010 Posted April 6, 2010 I'm sure you've created Restore points along the way. Restore Windows to a date that precedes the point in time you started having the problem. Maybe it's related to a Windows update. Have you purged the drawing? Have you run an Audit on the drawing? Maybe it is corrupted. Are you working off of a network? Quote
ninh Posted April 6, 2010 Author Posted April 6, 2010 I have 2008 and some of my co-workers are 2005,& 2009. Quote
ninh Posted April 6, 2010 Author Posted April 6, 2010 Yes I purge the drawing and Audit. Some one in my office let me to do that Quote
ninh Posted April 6, 2010 Author Posted April 6, 2010 Yes You are right, after my computer update the window xp and it starte to get the problem Quote
ReMark Posted April 7, 2010 Posted April 7, 2010 Is it one particular drawing you're having the problem with or any/all drawings? Quote
ReMark Posted April 7, 2010 Posted April 7, 2010 Is anyone else in the office experiencing the same problem? Quote
ninh Posted April 7, 2010 Author Posted April 7, 2010 no only my computer, but no one know what happen Quote
