2009, How to remove ribbon and replace with the old drop down menues????
How can I replace the ribbon with the drop down menues like in its previous versions? Please dont tell me to switch to a different workspace that does not keep my buttons where I want them.
IIRC... Ribbonclose & Menubar
Or look at the lower right corner. You should see a drop'down' button there to switch workspaces. I believe the default workspace is "2d drafting & annotation" so that is what you should see there at the moment. Clicking it should enable you to select the "AutoCAD classic" workspace.
reading>you.
Nope & nope (unknown commands):(
That worked here.
MikeP: to enable the dropdown menu's try the LISP expression (setvar "MENUBAR" 1). Could be variables / commands introduced in 2010, although that does not seem likely
reading>you.
Crap sorry about that.
Unknown commands? :?
Are you sure you typed them in correctly?
RIBBON displays the Ribbon
RIBBONCLOSE closes the Ribbon
MENUBAR = 1 displays the drop down menus
MENUBAR = 0 hides the drop down menus
Do you have all available updates and hotfixes installed for 2009?
You may need to run a repair on your installation if you are getting an "Unknown Command" message.
That worked here.
lol, its all good
See I think I found my problem..... Im an idiot! I have both my 2007 and 2009 open,I was trying that in my 07 version. works great in 09
Thanks all:D
