I've done it!
(DEFUN C:textlayer()
(setq new_layer "EC_TEXT")
(if
(not
(tblsearch "layer" new_layer))
(command "_layer" "m" new_layer "LW" "0.25" new_layer "C" "7" new_layer ""))
(setq old_layer "EC_DATA_EQPM_E")
(setq ss1 (ssget "X" (list (cons 0 "*TEXT")(cons 8 old_layer))))
(command "_CHPROP" ss1 "" "LA" new_layer "")
(PRINC)
...and it works...one more question.
I now want to make some changes to some additional layers
So
(DEFUN C:trial()
setq line_layers "EC_DATA_EQPM_E" AND "EC_GENL_CONT_E"
;so that line_layers will give both layers
(setq line_layers "EC_DATA_EQPM_E"+"EC_GENL_CONT_E")
(command "_layer" "m" line_layers "LW" "0.8" line_layers "C" "7" line_layers "")
(PRINC)
So then it should change the properties of both layers...how do i get it to do this AND function, or do i have to do them separately?
Cheers,
Marcus
  • Replies 33
  • scaramangamp
    12
  • Lee Mac
    10
  • jammie
    4
  • alanjt
    4
I would approach it this way:
(defun c:TxtLay (/ Layer ELST ENT I NEWLAYER OLDLAYER SS)
 (setq OldLayer "EC_DATA_EQPM_E,EC_GENL_CONT_E"
       NewLayer "EC_TEXT")
 (defun Layer (Nme Col LWgt)
   (or (tblsearch "LAYER" Nme)
       (entmake (list (cons 0 "LAYER")
                      (cons 100 "AcDbSymbolTableRecord")
                      (cons 100 "AcDbLayerTableRecord")
                      (cons 2  Nme)
                      (cons 70 0)
                      (cons 62 Col)
                      (cons 370 LWgt)))))
 (if (setq i -1 ss (ssget "_X" (list '(0 . "TEXT") (cons 8 OldLayer))))
     (Layer NewLayer 7 25)
     (while (setq ent (ssname ss (setq i (1+ i))))
       (setq eLst (entget ent))
       (entmod (subst (cons 8 NewLayer) (assoc 8 eLst) eLst))))
   (princ "\n** No Text Found **"))
 (princ))
You already seem to have some grasp on what DXF codes are, so I would persist with using them IMO.
Lee
Thanks Lee,
Does anybody know what is wrong with this draw order lisp - i am trying to get it to send the layer ""2D-EL-IT*|EC_GENL_CONT_E"" to the front. (the layer has a mix of objects on it)
(defun c:draworder3()
(setq layer_1 "2D-EL-IT*|EC_GENL_CONT_E")
(setq selection (ssget "X" '(8 . layer_1)))
(command "_draworder" selection "" "F")
Any help would be really appreciated.
Thanks,
Marcus
Warning! - very basic question
What do the number after the list(cons 0 or -4 or 8????
i'm slightly confused..cheers!
Thanks Lee,
Thanks,
Marcus
Change
to
(setq selection (ssget "_X" (list (cons 8 layer_1))))
The numbers are the DXF code.
Paste this into the command line and click on an object.
(entget (car (entsel)))
However, you should add an IF or AND check to make sure the selection is filled before executing the DrawOrder command.
eg.
(defun c:draworder3 (/ layer_1)
 (if (setq selection (ssget "_X" (list (cons 8 layer_1))))
   (command "_.draworder" selection "" "_F")
 ) ;_ if
) ;_ defun
I'm confused about your layer name. "|" means it's an XRef layer. You can't select nested XRef layers.
Thanks for the link Lee, that is perfect.
Thanks for spotting my error Alanjt...i have now corrected it.
I think you have found my problem!
I am trying to change the order of xrefs in a sheet file (where there is no content just xrefs). Therefore my draworder method won't work on the sheet files...
Does anybody know how you can change the order of xrefs?
Also,
Does anybody know how to make setq xxx "two different layers"....so that when i type xxx in future it would refer to both layers? (i tried to explain this problem at the top of the page - 3.47pm)
Many thanks,
Marcus
Well done with the progress so far, keep up the good work!
Lee actually has show this on the 04:33 pm post. A comma can be used to accept multiple arguments
 (setq OldLayer "EC_DATA_EQPM_E[color="Red"][b],[/b][/color]EC_GENL_CONT_E"
       NewLayer "EC_TEXT")
This will select objects on layer "EC_DATA_EQPM_E" and "EC_GENL_CONT_E"
Just FYI selection filters accept many wildcards. Have a look at WCMATCH in the AutoCADs Developers Help files
;Select lines & arcs only
(ssget (list '(0 . "line,arc"))))
;Select everyting but lines
(ssget (list '(0 . "~line"))))
Perfect..thanks Jammie!
Oh didn't see that..thanks Lee
You're welcome :)
If I were you at this point, I would make sure that you understand everything that is going on in the 4:33 post (take it apart line by line) - if you can get your head around the process that I used - there is not much that you cannot modify using the DXF codes.
As always, if you do have any questions about any code posted, just ask.
Lee
Quick question...
Do i need to make any adjustment to my lisp code if i want it to run without a prompt? So i can make it run on many files in a batch system and don't have to type anything into the command line for each file.
Cheers,
Marcus
ssget "X" mode will automatically search the drawing database, with no selection prompt, so no change would be needed.
You would need to call the LISP like this:
(c:LispSyntax)
Lee
  • 3 weeks later...
What if you what to pick multiple layers and have them change to specific layer.
Say I have a different layer for 1/4 and 1/2 scale. I have one for pipe, duct, ect. and I want to be able select and change multiple text entries at once.
For example
"m-text4-pipe" to "m-text8-pipe"
"m-text4-duct" to "m-text8-duct"
What would be the best way to handle this.
Any help would be greatly appreciated
Randall
