Any idea why the vl- functions have some charactures as Upper case? Is is so its easier to read?
Example:
Why do you always see it as "vlax-curve-getDistAtParam"
instead of "vlax-curve-getdistatparam"?
Not really a serious question, just curious.
LISP is not case-sensitive, so yes, I would assume that to be the mostly likely explanation.
You can find here a guideline about naming variables (SubMain - Professional C#/VB .NET Coding Guidelines) – even if intended for .Net programmers there is a lot of useful information for good coding habits, no matter the language you use.
Regards,
Very cool msasu, and thanks to both of you.
