Open a file in another window
In My Work One Of Computer When U Open Another File And Autocad Is Open
A New File Open In A New Autocad
And If U Want To Open Third
What Is The Answer??
SDI=0 if you want to open multiple dwgs in the same session.
  • 4 weeks later...
thank you but thit is not answer I TRY IT AND TRY
TOOLBAR
BUT THE BROBLEM STILL
I would have given the same answer as lpseifert but in case you want only one document per AutoCAD session you need the opposite - SDI=1
You means 2 autocad open with files?
yes you can open a lot of file in 1 autocad if y choose open fom file
but when you open another file from computer double click another another autocad open
third autocad
and so on
that problem not appear in ms word or excell
