abmacomber Posted August 22, 2008 Posted August 22, 2008 I have been using autocad 2000 for a couple of years now. I have it pretty much figured out in terms of the things I need to to. I just switched to 2008 and I cannot get a .jpg file into my drawings. I can open old files with jpegs already attached and they show up fine in xref manager, I cant find any options for inserting a jpeg. Quote
haya Posted August 22, 2008 Posted August 22, 2008 I have been using autocad 2000 for a couple of years now. I have it pretty much figured out in terms of the things I need to to. I just switched to 2008 and I cannot get a .jpg file into my drawings. I can open old files with jpegs already attached and they show up fine in xref manager, I cant find any options for inserting a jpeg. I have a little experiance in autocad but you try to copy the photo in JPG file then paste it into autocad drowing , I think that may help you.... Quote
abmacomber Posted August 22, 2008 Author Posted August 22, 2008 I have tried but it only displays a small white box with the file name on it. Quote
haya Posted August 22, 2008 Posted August 22, 2008 I have tried but it only displays a small white box with the file name on it. you should first open the file using paint program then select the photo copy it and past pleas try it and tell me if it is work Haya Quote
BOB'27T Posted August 22, 2008 Posted August 22, 2008 Try using the IMAGE command. It will let you insert a jpeg that way. You will need to scale it accordingly. Quote
haya Posted August 22, 2008 Posted August 22, 2008 Try using the IMAGE command. It will let you insert a jpeg that way. You will need to scale it accordingly. I try the command but show me any cad file just... another question how can I add a signature I am a new subsicriber !!!! Quote
Cad64 Posted August 22, 2008 Posted August 22, 2008 another question how can I add a signature I am a new subsicriber !!!! Once you put up 10 technical posts, you will get full member benefits. Read this thread: http://www.cadtutor.net/forum/showthread.php?t=9177 Quote
haya Posted August 22, 2008 Posted August 22, 2008 Once you put up 10 technical posts, you will get full member benefits. Read this thread: http://www.cadtutor.net/forum/showthread.php?t=9177 Thanks for reply... I will try to be an active member to help other and to get full benifits.. but I hope my work in accounting didn`t take more time Haya Quote
BOB'27T Posted August 22, 2008 Posted August 22, 2008 Save the image to whatever folder you want (i.e. My Documents). When you type in IMAGE, go to the first drop down arrow and select attach image. It will bring up your directory, then just select the image from the appropriate file. Quote
haya Posted August 22, 2008 Posted August 22, 2008 Save the image to whatever folder you want (i.e. My Documents). When you type in IMAGE' date=' go to the first drop down arrow and select attach image. It will bring up your directory, then just select the image from the appropriate file.[/quote'] Thanks alot... Quote
abmacomber Posted August 22, 2008 Author Posted August 22, 2008 1. I have tried copying from photoshop then pasting into cad. It gives me that white box. 2. The image command takes me to the external references window. the only file types it allows me to import on the tab at the top left are, dxf, dwg and dgn. Quote
haya Posted August 23, 2008 Posted August 23, 2008 1. I have tried copying from photoshop then pasting into cad. It gives me that white box. 2. The image command takes me to the external references window. the only file types it allows me to import on the tab at the top left are, dxf, dwg and dgn. That`s happen to me at first time but I try what BOB said about imprting image it is work ,,,there is the solution.. "Save the image to whatever folder you want (i.e. My Documents). When you type in IMAGE, go to the first drop down arrow and select attach image. It will bring up your directory, then just select the image from the appropriate file." Haya Quote
daft vader Posted August 24, 2008 Posted August 24, 2008 Its click on insert at the top then scroll down to raster image reference then direct it to your image in its saved folder select it then follow instructions on inserting it Quote
abmacomber Posted August 25, 2008 Author Posted August 25, 2008 That`s happen to me at first time but I try what BOB said about imprting image it is work ,,,there is the solution.."Save the image to whatever folder you want (i.e. My Documents). When you type in IMAGE, go to the first drop down arrow and select attach image. It will bring up your directory, then just select the image from the appropriate file." Haya I know that this is the way to do it however I do not have the option to insert a jpeg. Refer to my earlier posts. Cad64- Yes I am using LT Quote
