asos2000 Posted April 10, 2010 Posted April 10, 2010 Hi all I created this routine and want to create a table I tried to study a routine has a table but faild Can I get some help in creating this table? Code (defun c:EC-COORD () (vl-load-com) (defun *error* (msg) (setvar "CMDECHO" oldEcho) (setvar "clayer" OldCLyr) (princ)); end *error* ; subroutine (defun Pointblock () (entmake '((0 . "BLOCK") (100 . "AcDbEntity") (67 . 0) (8 . "0") (100 . "AcDbBlockReference") (2 . "Planning-Point") (10 0 0 0) (70 . 0))) (entmake '((0 . "CIRCLE") (100 . "AcDbEntity") (67 . 0) (8 . "0") (62 . 7) (100 . "AcDbCircle") (10 0 0.000000000000014 0) (40 . 0.1))) (entmake '((0 . "LINE") (100 . "AcDbEntity") (67 . 0) (8 . "0") (62 . 7) (100 . "AcDbLine") (10 -0.141421356237316 0.141421356237302 0) (11 0.141421356237288 -0.141421356237302 0))) (entmake '((0 . "LINE") (100 . "AcDbEntity") (67 . 0) (8 . "0") (62 . 7) (100 . "AcDbLine") (10 -0.141421356237316 -0.141421356237302 0) (11 0.141421356237288 0.141421356237302 0))) (entmake '((0 . "ENDBLK") (100 . "AcDbBlockEnd") (8 . "0"))) (princ)) (defun Layer () (entmake (list (cons 0 "LAYER") (cons 100 "AcDbSymbolTableRecord") (cons 100 "AcDbLayerTableRecord") (cons 2 "EC-TEXT-22-SCALE") (cons 70 0) (cons 62 10))) (entmake (list (cons 0 "LAYER") (cons 100 "AcDbSymbolTableRecord") (cons 100 "AcDbLayerTableRecord") (cons 2 "EC-SYMBOL") (cons 70 0) (cons 62 13))) (princ)) ; mainroutine (Pointblock) (Layer) (setvar "cmdecho" 0) (setq OldDynmode (getvar "dynmode") OldDynprompt (getvar "dynprompt") OldCLyr (getvar "clayer")) (initget "Meter MILLImeter") (setq Dwg:Unts (getkword "\nWhat is drawing units? [Meter/MILLImeter]: ")) (if (= Dwg:Unts "Meter") (progn (command "_.-style" "EC-22-0.01" "romans.shx" 0.22 "0.8" "0" "n" "n" "n") (setvar "DIMTXT" 0.22) (setq BlkScl 1.0) )) (if (= Dwg:Unts "MILLImeter") (progn (command "_.-style" "EC-22-100" "romans.shx" 220 "0.8" "0" "n" "n" "n") (setvar "DIMTXT" 220) (setq BlkScl 1000.0) )) (if(not num:Pref)(setq num:Pref "")) (if(not num:Suf)(setq num:Suf "")) (if(not num:Num)(setq num:Num 1)) (setq num:Size (rtos (getvar "DIMTXT"))) (setq oldSize num:Size oldPref num:Pref oldSuf num:Suf oldStart num:Num actDoc (vla-get-ActiveDocument (vlax-get-acad-object)) ); end setq (if(=(vla-get-ActiveSpace actDoc)1) (setq actSp(vla-get-ModelSpace actDoc)) (setq actSp(vla-get-PaperSpace actDoc))); end if (if(null num:Size)(setq num:Size oldSize)) (setq num:Pref (getstring T (strcat "\nPrefix: <"num:Pref">: "))) (if(= "" num:Pref)(setq num:Pref oldPref)) (if(= " " num:Pref)(setq num:Pref "")) (setq num:Suf (getstring T (strcat "\nSuffix: <"num:Suf">: "))) (if(= "" num:Suf)(setq num:Suf oldSuf)) (if(= " " num:Suf)(setq num:Suf "")) (setq num:Num (getint (strcat "\nStarting number <"(itoa num:Num)">: "))) (if(null num:Num)(setq num:Num oldStart)) (princ "\n<<< Insert numbers or press Esc to quit >>> ") (while T (setq curStr (strcase (strcat num:Pref(itoa num:Num)num:Suf))) (setq NumPnt (getpoint "\nPick POint ")) (setq NumPont (list (- (car NumPnt) (* 3 (getvar "DIMTXT"))) (+ (cadr NumPnt) (* 3 (getvar "DIMTXT"))) (caddr NumPnt))) (entmakex (list (cons 0 "TEXT") (cons 1 curStr) (cons 7 (getvar "textstyle")) (cons 8 "EC") (cons 10 NumPont) (cons 11 NumPont) (cons 40 (getvar "DIMTXT")) (cons 50 45) (cons 72 1) (cons 73 2))) (entmakex (list (cons 0 "INSERT") (cons 2 "Planning-Point") (cons 8 "EC-SYMBOL") (cons 10 NumPnt) (cons 41 BlkScl) (cons 42 BlkScl) (cons 43 BlkScl))) (setq Pnt:Lst (cons(list curStr (car NumPnt) (cadr NumPnt) (nth 2 NumPnt)) Pnt:Lst) tLst (list (1 0 "Point")(1 1 "X")(1 2 "Y")(1 3 "Remarks")) vlaTab (vla-AddTable mSp (vlax-3D-point '(0 0 0)) (+ 1(/(length tLst)4)) 4 (* 3 (getvar "DIMTXT")) (* 20 (getvar "DIMTXT")))) ; table (setq num:Num(1+ num:Num)) ); end while (princ) |; ); end of c:num (princ "\n http:\\www.a-a-econstruct.com ") (princ "\n Type EC-COORD to run. ") Quote
asos2000 Posted April 13, 2010 Author Posted April 13, 2010 WOW This thread will break a record around 2000 views without single reply. Quote
