hi guys :) I have 6 cameras with different views in interior space, is there a way to set up renderer so that it automatically renders these 6 views, rather than waiting after each render, and then rendering the next view again? thanks :)
Short answer: Yes
Long answer: Check your Max help files for information on Batch Rendering. I've never done it myself, so I can't walk you through the steps, but I think the help files will give you a pretty good description of the procedure.
Thanks that is what I needed, what it is actually called, thanks :)
