Moe` Posted April 16, 2010 Posted April 16, 2010 To make a change to the "Sheets" you have to edit the family. So you need to load the sheet into the drawing, I would duplicate it and then edit the duplicate. -Once the Sheet is in the project go to it -Pick the Sheet -Right click -Edit Family -Edit the sheet to the way you like it -insert -load into project Then when you pick the sheets you can load the "D-Sheet My way" or what ever you named your duplicate. its late and i did that off of the top of my head i'll foloow my directions tomorrow and edit any wrong steps Quote
