BuntyBunty Posted April 20, 2010 Posted April 20, 2010 Greetings, I have a drawing where the viewport is invisible and I can't actually view it. I can view what is inside the vport, I can double click inside it and edit the drawing in modelspace through it. But even with all layers turned on with full visibility I can't see the viewport in order to move or edit it. Can anybody help? Many thanks. BB. Quote
ReMark Posted April 20, 2010 Posted April 20, 2010 You can select it though (with a crossing window) right? Quote
BuntyBunty Posted April 20, 2010 Author Posted April 20, 2010 Nope, I'm afraid not. The actual viewport line does not appear to be visible at all. Quote
merdrignac Posted April 20, 2010 Posted April 20, 2010 Is The layer the viewport's on frozen or off? Quote
BuntyBunty Posted April 20, 2010 Author Posted April 20, 2010 Nope, all layers are turned on, nothing is frozen. Quote
BuntyBunty Posted April 20, 2010 Author Posted April 20, 2010 Problem solved. In the layer control manager the vport layer was frozen in the 'current vport freeze' column which was outside of the visible layer manager all the way to the right, I had to scroll all the way over to get to see it and then turn it back on. Cheers. Guys. BB. Quote
ReMark Posted April 20, 2010 Posted April 20, 2010 Another example of an OIE (Operator Inflicted Error). If it wasn't for OIE's we'd cut out 50% of the questions posted here. Quote
lpradobr Posted October 19, 2016 Posted October 19, 2016 :) Problem solved. In the layer control manager the vport layer was frozen in the 'current vport freeze' column which was outside of the visible layer manager all the way to the right, I had to scroll all the way over to get to see it and then turn it back on. Cheers. Guys. BB. That's it! Now I can manage that ghost viewport. Thank you guys Quote
