a8amg Posted April 20, 2010 Share Posted April 20, 2010 Hi there, I'm pretty new to 3D Autocad, but have used Autocad for years. I'm doing a 3D drawing and want to show some pipes under the ground, but not anything else that is hidden. How do I do it? Autocad 2007 - English SP1 Thanks Andrew Quote Link to comment Share on other sites More sharing options...
ReMark Posted April 20, 2010 Share Posted April 20, 2010 Layer Isolate? Is this in model space or in a layout using a viewport? Quote Link to comment Share on other sites More sharing options...
a8amg Posted April 20, 2010 Author Share Posted April 20, 2010 Layer Isolate? Is this in model space or in a layout using a viewport? It's in Model Space. I still want to see all other layers, but in 3D Hidden View, not 3D Wireframe Thanks Quote Link to comment Share on other sites More sharing options...
Hugh_Compton Posted April 20, 2010 Share Posted April 20, 2010 As well as layerIsolate you could simply take two elevations - one of the pipework and one of the environment. Then simply fade the environment. Another approach would be to use objecthide from here: http://www.3dcadmax.com/FreeAutoHide.htm It works in a similar way to AutoCAD 2011s isolate / hide / reveal commands. --------------------------------------- 3D AutoCAD Pipework - http://www.HerculeDesign.com/ Quote Link to comment Share on other sites More sharing options...
a8amg Posted April 20, 2010 Author Share Posted April 20, 2010 As well as layerIsolate you could simply take two elevations - one of the pipework and one of the environment. Then simply fade the environment. Another approach would be to use objecthide from here: It works in a similar way to AutoCAD 2011s isolate / hide / reveal commands. --------------------------------------- 3D AutoCAD Pipework - I'm using Autocad 2007, and don't believe it has Environment Fade (is that the same as layer fade?) Quote Link to comment Share on other sites More sharing options...
WtaDude0822 Posted April 22, 2010 Share Posted April 22, 2010 I want to make sure that I understand you. Are you wanting to plot a viewport with shadeplot set to hidden and have a 3d object in that view (underground piping) show up dashed? Quote Link to comment Share on other sites More sharing options...
David Bethel Posted April 22, 2010 Share Posted April 22, 2010 I do this kind of visible piping images quite often. It is a 2 step process. Plot the equipment, plot the piping. Bring the equipment in with hidden lines, piping as continuous. -David Quote Link to comment Share on other sites More sharing options...
