Hi,
I am having trouble with my xref setting. When I make a change to an xref and click on the reload xref link in the alert box that pops up on the screen of the drawing it is referenced into, all the layers come back on again.
If I open the xref manager and reload, it retains all the frozen layers.
I am familiar with the "visretain" command but this does not help with this issue.
Any suggestions!
I am working with AutoCAD 2004
Thanks
Try indexctl = 3
visretain = 1
xloadctl = 2
Hi
I set all three as you said on both the xref and the drawing it is xrefing into and I still have the same issue?
No problem if I reload through the xref manager but if I use the link in the alert baloon all the layers come back on!
Don't click the link in the balloon is all I can say.
