TimZilla
Edit Multiple Blocks (color) at once?
TimZilla
Let's say I have a whole bunch of blocks, and they are all different colors. I want to make them all one color without having to go into the block editor screen for each one.
there has to be a way.
Share this post
Link to post
WtaDude0822
Redefine the block with the color you need. Autocad will ask you if you want to update the current block definitions in the drawing.
Share this post
Link to post
dbroada
This really does come down to doing it right in the first place. You should only define colours & layers in blocks if you REALLY need to. It is far better to create your geometry on Layer 0 and use colour byLayer or byBlock. That way all you need do is put your blocks on a different layer or assign them a different clour and its all done.
Share this post
Link to post
TimZilla
Well, I have to put other peoples plans into my drawing. For instance the HVAC, machanical drawings. Those guys use about 20 different colors, and everything is a block. I like making all the other trades stuff a certain color and lock it. That way when I draw my piping I can focus.
If everyone did like you say, it would work just fine.
Share this post
Link to post
dbroada
in that case to answer your original question, I think programatically is about the only way.
Share this post
Link to post
BIGAL
You can edit a block and change all the stuff inside heres a lisp about changing the line type in every block where a particular line type was found to a different one.
I got the source from the forum here its called block edit
; my line only change
;(defun c:normblocks (/ adoc)
 (vl-load-com)
 (setq adoc (vla-get-activedocument (vlax-get-acad-object)))
 (vla-startundomark adoc)
 (vlax-for block (vla-get-blocks adoc)
   (if   (not (wcmatch (strcase (vla-get-name block) t) "*_space*"))
     (vlax-for   ent block
(if  (= (vla-get-linetype ent ) "solid" )
(vla-put-linetype ent "Continuous")
(princ (vla-get-name block))
);_ end of if
  ) ;_ end of vlax-for
     ) ;_ end of if
 (vla-regen adoc acactiveviewport)
 (vla-endundomark adoc)
complete code should be easy to change color
 (vl-load-com)
     (vlax-for   ent block
 ; (vla-put-color ent 0)
  (vla-put-linetype ent "Bylayer")
  (vla-put-lineweight ent aclnwtbyblock)
     ) ;_ end of if
 ) ;_ end of defun
(defun c:normblock (/ adoc selset)
 (vl-load-com)
 (if (setq selset (ssget "_:S:L" '((0 . "INSERT"))))
   (vlax-for ent (vla-item
         (cdr (assoc 2 (entget (ssname selset 0))))
         ) ;_ end of vla-item
     (vla-put-linetype ent "ByBlock")
   ) ;_ end of if
 ) ;_ end of defun
found color by layer
 (vl-load-com)
     (vlax-for   ent block
     ) ;_ end of if
Share this post
Link to post
TimZilla
This is wonderful BigAL, hopefully it works.
Share this post
Link to post
TimZilla
wow, I made all of these a Lisp file, loaded them into CAD. AND BOOM!
I can change ever single block to what ever color I want! simply by clicking on it and changing the color!
I do not have to go into the block edit!
just load, and it automatically makes every block perfect.
this is going to save me so much time BigAL. Just wanted to let you know you made somebody's life easier. Wow, I feel like I can take longer breaks now! Coffee? sounds good to me
Share this post
Link to post
BearDyugin
Another program for normalizing blocks the current drawing
Example call:
(Norm-blocks bit)
Invocation Arguments:
bit sum of any number of the following values:
1; layer of the object - "0"
2, line type of object - ByBlock
4, line weight of the object - ByBlock
8, line color object - ByBlock
16; scale line object - 1
nil or
(Norm-blocks 1); transfer all objects of all the blocks in the layer "0", without changing other settings
(Norm-blocks 2); change the type of lines of all objects of all the blocks on the "ByBlock", without changing other properties
(Norm-blocks 7); change the layer to "0" (1), the type of coils - at ByBlock (2); weight line - at ByBlock (4)
norm-blocks.lsp
Share this post
Link to post
tasos85
Can you please explain how to load the lisp file, i don't know how to use lisps:(. I have many blocks I want changed to the same color and cannot do it otherwise
 (vl-load-com)
     (vlax-for   ent block
     ) ;_ end of if
 ) ;_ end of defun
 (vl-load-com)
   ) ;_ end of if
 ) ;_ end of defun
Share this post
Link to post
nod684
Copy the code that Bigal sent you.
Paste it in notepad and save it with .lsp as an extension
in AutoCAD, type Appload
browse for the lisp file
once found, click load then close
then type normblocks at the command line
Share this post
Link to post
rbracken
This thread has really helped. Had a lot of blocks to edit.
Is there are a way to revert the blocks back to original colours?
Also the blocks are no longer visible in paperspace. Is there a reason for this?
I am a novice user and currently on trial at a new job, so any advice would be great!
Share this post
Link to post
SLW210
If they are not visible in paper space, check that the Layer is not frozen per viewport.
Share this post
Link to post
KFesting
Hi TimZilla,
Just wondering how you used this one? I've created the lisps' for them but do you execute them one after another?
Share this post
Link to post
Bhull1985
You can use the command (load "yourlisp.lsp")
and/or you can drag/drop lisp files into the cad window to load them
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
