zaygee Posted April 22, 2010 Posted April 22, 2010 Excuse me, when I use the ISO dash space linetype, there is not change. I've only see the continuous lientype. would you mine telling me how should I solve this problem. Quote
Car5858 Posted April 22, 2010 Posted April 22, 2010 Reduce the "ltscale" factor and see if the line type changes. Quote
zaygee Posted April 22, 2010 Author Posted April 22, 2010 Reduce the "ltscale" factor and see if the line type changes. thanks for your attention. I'll try it now. Quote
iskalipsi Posted April 22, 2010 Posted April 22, 2010 If reducing the scale factor wont do it, then try increasing it. Try 75. Units are you using? Quote
dbroada Posted April 22, 2010 Posted April 22, 2010 out of interest, what template file are you starting from? If you are using acad.dwt try using acadiso.dwt instead. A different line definition file is used more suited to metric drawings. Quote
