kme2222 Posted April 23, 2010 Posted April 23, 2010 I have AutoCAD 2010 installed on my machine, but I just installed 2009 so that I can use ESRI's ArcGIS for AutoCAD (not yet available for 2010). When I open up 2009, I can't see any of the tool palattes or menu options. See the attached images. Please help! Binder1.pdf Quote
kme2222 Posted April 23, 2010 Author Posted April 23, 2010 Thanks for your advice. I think that's on the right track, but I loaded every .cui in the folder that CUILOAD took me to. I now have toolbars everywhere like in older AutoCAD versions, but I don't want these. I'm trying to get the ribbon tabs at the top. I find those much more useful. When I bring up the Customize User Interface window (CUI), I can see where a new ribbon tab can be created, but none are pre-loaded. The attached images are of the CUI window, first in 2009, then in 2010. When I installed 2010, all the ribbon tabs shown were already there. Binder2.pdf Quote
ReMark Posted April 23, 2010 Posted April 23, 2010 You have a command line right? Have you tried typing in the word RIBBON? Quote
kme2222 Posted April 23, 2010 Author Posted April 23, 2010 Typing the RIBBON command brings up the toolbar shown in the attached image ribbon.pdf Quote
kme2222 Posted April 23, 2010 Author Posted April 23, 2010 Actually, it doesn't. That toolbar must have already been up. When I type RIBBON, nothing happens Quote
ReMark Posted April 23, 2010 Posted April 23, 2010 Have you tried changing workspaces? Can you get to Tools > Options > Profiles tab and see what profile is loaded maybe even do a Reset (button in column on right). Quote
kme2222 Posted April 23, 2010 Author Posted April 23, 2010 It doesn't give me any workspaces to choose from. (see attached) Workspace Settings.pdf Quote
kme2222 Posted April 23, 2010 Author Posted April 23, 2010 This is what I see when I reset the profile reset profile.pdf Quote
ReMark Posted April 23, 2010 Posted April 23, 2010 Stubborn little problem isn't it? OK, let's try this. I found a thread at the AutoDesk Discussion Group that appears similar to yours. The last reply in the link I have provided below is by David Dyche of AutoDesk. He offers three possible solutions. Take a moment, pop over, and read through his post. Think carefully before proceeding. Good luck. https://discussion.autodesk.com/forums/thread.jspa?threadID=766294&tstart=0 I have to go out for a little while but I'll check back upon my return. Quote
kme2222 Posted April 23, 2010 Author Posted April 23, 2010 Method 1 did it! I guess there was just something wrong with the ACAD.cui that was in the Application Data. It was about 1/10 of the size of the one that was in the Program Files. When I replaced it and restarted AutoCAD, it was like cranking up a brand new car, everything was perfect! THANK YOU FOR YOUR HELP! Quote
ReMark Posted April 23, 2010 Posted April 23, 2010 Praise the Lord and pass the cocktail peanuts. Houston...we no longer have a problem! I am glad to hear your problem has been resolved and even more so since you did not have to go to methods 2 and 3. Thank you for updating us. And by the way, you're entirely welcomed. Quote
