The leader line adjusts its position when I place it
I use the Qucik Leader alot in my work. Here is the process;
1) First I select the start point of the leader line.
2) I draw the line and right click when the position is correct.
3) I write in the text.
4) When I've finished writing I right click again to exit the command.
What happens now is that the leader line adjusts itself a little, not much but it happens. I've noticed that if I choose an arrow size of 0 instead of my usual 100, it doesn't happen, iow the text starts at the exact point where I end the leader line. How can I keep my arrow size at a 100 and still have the leader line stay put?!
Just a shot in the dark - Is your dimension scale set wrong for this dwg?
