I use my numpad to change views, and I want to keep my current selection active. Now I did this with the macro:
^C^C_-view _front;^C^C^P(sssetfirst nil (ssget "_P"))(princ)
But now it also selects my previous selection even if i had unselected it.
So I went looking to something like this:
(IF ([b]sset[/b])(^C^C_-view _top;sset^C^C^P(sssetfirst nil (ssget "_P")(princ)))(^C^C_-view _top));
But that didn't work, first I don't know if the if function works in macro and I have to make a autolisp file instead? Futher more I don't know wich if function I should use to check for selection.
In short I want to do this:
If selection is active: changeview and keep selection
If selection is not active just change view do not retrieve previous selection.
Try something like this...
(if (ssget "_I") (progn (command "_.-view" "_top") (sssetfirst nil (ssget "_P"))) (command "_.-view" "_top"))(princ)
LISP version (with all default views as a choice):
(defun c:Test (/ ss op)
 (setq ss (ssget "_I"))
 (initget 0 "Top Bottom Left Right Front bAck SW SE NE NW")
 (if (setq op (getkword "\nView option [Top/Bottom/Left/Right/Front/bAck/SW/SE/NE/NW]: "))
   (progn (command "_.-view" (strcat "_" op))
          (sssetfirst nil ss)
I'm not much of a button person (don't know if this will work), but if you are wanting to avoid creating a command that has to be loaded, and can get it to load it from a Toolbar, you can try this (anonymous function):
((lambda (ss / op)
           (princ (strcat "\nView: \"" op "\""))
           (sssetfirst nil ss)
 (ssget "_I")
Fantastic idea BTW.:thumbsup:
Sadly, I never change from Top view.
The numpad idea is from blender.org, it is very handy because you can map out the views pretty good on the numpad. I currently have them mapped under ctrl+numpad1 etc.
And now Thanks to you it works flawless.
So awesome to ignore the current line is not in current ucs blablabla, just switch view and do it again, no more looking for your selection using some cmd to get previous selection back on.
Thanks for your help and i hope more people will like it!
btw same code for zoom cmd:
(if (ssget "_I") (progn (command "_.zoom" "all") (sssetfirst nil (ssget "_P"))) (command "_.zoom" "all"))(princ)
Zoom all is under ctrl+numpad 5
