http://www.cadtutor.net/forum/showthread.php?t=47161
i'm posting a link to a question raised before, until we came to a conclusion that the only way is to LISP it!
Can i set AutoCAD to automatically draw circle by diameter rather then radius. Perhaps load it in Appload startup so it get's the definition of how to apply command circle...
Any working ideas?
Quickie...
(defun c:CD (/ pt)
 (if (setq pt (getpoint "\nSpecify center point for circle: "))
   (command "_.circle" "_non" pt "_diameter")
cheers, works like a charm, need to learn this LISP :)
You're welcome. :) It's saves worlds of time.
