Bowl.Spliffson Posted April 28, 2010 Posted April 28, 2010 I am having trouble remember how to add commands into the right click menu. I know I have to go into the CUI file but once I'm there i can't remember which which sub section is for the right click. Thank you In advance Quote
CJJ Posted April 28, 2010 Posted April 28, 2010 In the CUI, I think you need to modify your "Shortcut Menus" and change your Context Menus there. Quote
alanjt Posted April 29, 2010 Posted April 29, 2010 In the CUI, I think you need to modify your "Shortcut Menus" and change your Context Menus there. That's right. Under that section, there will be several right-click menu options, you have to find the basic/generic one that applies to all right-clicks (unless you have something specific for certain objects). From there you can 'Create a command' and drag it into the right-click menu. It's cumbersome, but I spent the time to do it for a few randoms and was quite happy with it. Quote
