alanjt Posted April 30, 2010 Posted April 30, 2010 I check your lisp routine, oh boy ! It's not for beginner ! Is there an easy way to do that ? If I know the layout and layers name and if Im sure that these names will never change... Did you get it to run? Defining the layers is easy. When you say you know the layout, will the layout always have the same name? Quote
DubweiserTM Posted April 30, 2010 Author Posted April 30, 2010 I try it ! It's what I want but more "automatic" ! The layout and the layers will always have the same, instead if someone change it by error... Quote
alanjt Posted April 30, 2010 Posted April 30, 2010 I try it ! It's what I want but more "automatic" ! The layout and the layers will always have the same, instead if someone change it by error... Hmm, maybe something like this... Just edit the layers and layouts variable accordingly. (defun c:Test (/ layers layouts ctab ss) (setq l[color=Red]ayers "layer1,layer2,lay*" layouts '("Layout1" "Layout2")[/color] ctab (getvar 'ctab) ) (foreach x (layoutlist) (if (and (member x layouts) (setq ss (ssget "_X" (list '(0 . "VIEWPORT") (cons 410 x)))) ) (progn (setvar 'ctab x) (command "_.vplayer" "_Freeze" layers "_select" ss "" "") ) ) ) (and ctab (setvar 'ctab ctab)) (princ) ) Quote
DubweiserTM Posted April 30, 2010 Author Posted April 30, 2010 Yeah ! You're right ! This lisp is easier to understand for a beginner and it works ! Thank you very much ! Quote
alanjt Posted April 30, 2010 Posted April 30, 2010 Yeah ! You're right ! This lisp is easier to understand for a beginner and it works ! Thank you very much ! If you have any questions about it, just ask. Also, if you wish to continue with LISP, PM me your email addy and I'll shoot you some reading. Quote
marlo5 Posted July 3, 2013 Posted July 3, 2013 Try this as a MACRO. ^C^C_VPLAYER;F;*CRITDIM*,*MERCH*,*DIVISION*,*DIVISION_TEXT*,2EAS;A;; Where the Xref layers are: MERCH DIVISION DIVISION_TEXT And other layers in the drawing i want frozen are: CRITDIM 2EAS Add the macro to your own new toolbar and this will freeze ALL layers within 1 or all viewports within your drawing with just 1 Click. cheers marlo5 Quote
