hi could someone tell me how to permanently set my dim text hight it seems to be set at 2.5 mm so i have to click on every dim i do and set each one individually
thanks
You set the dimension text height in your dimension style dialogue.
You can have different heights for different dimension styles.
If you are using scaled paperspace viewports then the 'Overall dimension scale' that you set for the style will also affect the text height by multiplying the height set by the scale set.
thanks for your help have sorted it it now thanks again
