ids3rd Posted May 4, 2010 Posted May 4, 2010 Hi, I have to count up various electrical drawings from many different contractors and architects (light fittings). The cad blocks are never the same. Sometimes the items i need to count are not cad blocks but text (ie "G2E" next to a drawn image) I know i can qselect on text and cad blocks but sometimes this is impossible - due to over 100 variants. If i explode the cad blocks because they qselect the same i loose the value (i.e they all look the same and are named the same but have different labels or value) i have started using dataextraction which is very good. I select the CAD blocks and in the catergory filter, their attribute; and then I select non blocks "Mtext & Text" their contents and value. I then view the report on the screen and pull off the info i need. I have now noticed that it is possible to set-up a "LISP" file. I don't know how these work - but I basically think I could automate this either to a button or on startup. Either that or I would like "dataextraction" to remember my settings and output to a file. The thing is - unless you click on the right points you get masses of not needed data. Can anybody help. Quote
Lt Dan's legs Posted May 11, 2010 Posted May 11, 2010 I'd search in http://www.cadtutor.net/forum/forumdisplay.php?f=21. Lots of programs have been created there. You can find what you need without knowing lisp or VBA Quote
