rossiarchitecture Posted May 4, 2010 Posted May 4, 2010 Hello! My CTB files are called out as missing when I go to print. My drawings are showing up in the print preview and printing color rather than black and white. Typically, I can type in convertpstyles to alleviate this problem but it isn't working now. A message comes up that says "You should convert your color dependant plot style tables (CTB files) to names plot style tables (stb files) with convertctb before converting your drawing. We had a new server installed and all of my previous AutoCAD settings were not saved. It looks like everything is still pathed correctly, etc. Any ideas? Quote
ReMark Posted May 4, 2010 Posted May 4, 2010 You should still have the default monchrome.ctb along with the acad.ctb (color). Quote
rkmcswain Posted May 4, 2010 Posted May 4, 2010 Hello!My CTB files are called out as missing when I go to print. That is because AutoCAD can not find them in the path specified. Go into Options > Files Tab > Printer Support File Path > Plot Style Table Search Path. Make sure THAT PATH contains your CTB files. Quote
